Topic: Playlist Order lost
Hi all, Just recently done a V8.2 upgrade. And discovered that all my created Playlists have lost their natural order of play. As I change my main list to BPM order and then went into my playlists, these also have been re-arranged into BPM order. And if I then do by Artist the playlists also appear in that order. This did not use to happen and is now a major issue for myself as I use to note playlist order for years and then started to rely on VDJ as it use to hold the order in place regardless. Can this be put back?
geposted Sun 31 Jul 16 @ 9:34 am
Load your playlist in the browser, right click on one of the browser columns, select "reset sort order" at the top and see what happens .....
geposted Sun 31 Jul 16 @ 9:49 am
Thanks, I had wondered if that would do it, and it did.
However since posting, I had an epiphany.... went into Settings and Options (browser section) keepSortOrder - switched from Yes to No and voila! keeps all my playlists in their original view rather than changing to match my main view.
Sometimes just talking/typing out loud solves so many things :-)
geposted Sun 31 Jul 16 @ 9:54 am
