i have just downloaded and paid for a subscription for VDJ8 and when it asks me to log in it says it cannot connect to servers.
geposted Sun 31 Jul 16 @ 1:16 pm
Support staff wrote :
geposted Sun 31 Jul 16 @ 2:52 pm[ selected best answer by locoDog on Thu 03 Oct 19 @ 8:46 am ]
Selected as best answer geposted Sun 31 Jul 16 @ 2:52 pm
You have most likely been using an illegal cracked version of VDJ in the past, which has messed with your hosts file. You need to rectify that.
See here
See here
This did not help ion my case
geposted Sun 14 Aug 16 @ 1:57 am
.....and no one here can help unless you give a lot more detail.
geposted Sun 14 Aug 16 @ 6:51 am
just managed to find the problem, apparently you have installed a cracked version of VJ7 in the past so when you connected your pc to it autoomatically connects it that old host . so what you should is first( this part is not entirely necessery but rather do it now instead of having other bugs later )go to C/programs86 or 64/virtual DJ and delelte the files from virstual DJ 7.
and to fix the log in problem go to C/Windows/system32\drivers\etc\hosts and open it with notepad and search a "127.0.0.1 live.virtualdj.com " delete it and save the file to the desktop since it won't let you save it directly to that folder and then delete the host file and replace it with the saved file and it should work. allready tried it on two users.
geposted Wed 17 Aug 16 @ 9:27 am
Why are people installing cracked software in the first place. Idiots.
geposted Wed 17 Aug 16 @ 9:36 am
Sorry about the repeated posts. But this thread had different content from the other i posted in. Is there a fix for a mac?
geposted Tue 28 Feb 17 @ 11:10 pm
hello it shows that i cannot connect my virtual dj to the internet what should i do'?
geposted Wed 14 Mar 18 @ 1:39 pm
Same thing if you've ever had a cracked version of VDJ on your laptop
See the answer above
geposted Wed 14 Mar 18 @ 2:54 pm
We cannot connect to virtual dj servers
geposted Thu 06 Sep 18 @ 10:20 am
i cannot conect to server because its says system unable because of crack installed????
geposted Tue 02 Oct 18 @ 8:44 pm
how do i get out of this situation problem is im not that good with laptops
geposted Tue 02 Oct 18 @ 8:46 pm
Read the thread!
geposted Tue 02 Oct 18 @ 8:55 pm
ive tried the thread!
geposted Thu 04 Oct 18 @ 7:35 pm
when i click on the thread it opens up new page but only virtualdj.com is high lighted
geposted Thu 04 Oct 18 @ 7:45 pm
some one help me please
moderator answered in other thread
geposted Thu 03 Oct 19 @ 8:20 am
