Hi, i want to add the command "mix now" (item in the automix section) to a "custom knob".
How do i do this?
grtz
How do i do this?
grtz
geposted Sun 31 Jul 16 @ 5:56 pm
https://www.youtube.com/embed/nGbw2RHV_j0
If you have updated to version 8.2, then the Custom buttons may not be available in the default 2 decks skin. To get those, click on the Skin Layout menu button at the top and select the option "Show some empty buttons"
In the 4 Decks default skin, you will have to use the Custom ad page and the Pad Editor to get custom buttons.
geposted Sun 31 Jul 16 @ 6:02 pm
Thanx...
geposted Sun 31 Jul 16 @ 10:53 pm
