Topic: Strange Update
My VDJ 8.2 just updated to Build 3342.1196 in a very strange way. I got a message reading "Your Program Has Just been Updated. Do You Want To Use The New Version Now?" Usually I get the message that there is a new version available do I want to update?. Then there is a change log list.There was no change log list but I clicked yes and the new version appeared, 3342. I went to the website and looked under change logs and the last one is 3324 on July 18th. I may be old and do not see like I did in 1968 but even my cat who is looking at the version sees 3342. What is going on?
geposted Mon 01 Aug 16 @ 12:20 am
The same thing happened to me as well. The update (3342) is an early acces build and I had to go onto the website to see the change log.
geposted Mon 01 Aug 16 @ 12:49 am
I could not find the change log. The last one was for 3324! If you found it could you let me know where it is?
geposted Mon 01 Aug 16 @ 12:53 am
From http://www.virtualdj.com/products/virtualdj/changelog.html?view=advanced
BUILD 3342 (2016-07-30)
-ID3 tag ratings are compatible with windows explorer/media player ratings
-Implement VST GUIs on Mac
-Fix lockup on startup when skin error on mac
-Fix text result for get_time with unit parameter
-Fix slideshow fade time not remembered
-Fix loop_pad_mode x queries
-Add option 'fxProcessing' to select pre- or post-fader effects
-Improve camera plugin performance and automatic resolution selection
-Fix getting dimmed colors from color action
-Fix moving files in list while automix is removing played files
geposted Mon 01 Aug 16 @ 12:58 am
Thanks. As usual very helpful...
geposted Mon 01 Aug 16 @ 1:01 am
I can't tell if that was sarcastic or not :p
geposted Mon 01 Aug 16 @ 1:06 am
where did the AUX button go? Geez . i was in the middle of a DJ set . my mic requires the AUX button. anyone know?
geposted Mon 01 Aug 16 @ 4:31 am
I may be wrong, but some buttons only appear if you set the corresponding Inputs in the sound config.
geposted Mon 01 Aug 16 @ 12:10 pm
I was being serious for a change!!!!
geposted Mon 01 Aug 16 @ 3:01 pm
