Topic: 8.2. Pad Page
Hi, please, you can be used Pads page also in midi controller pads? (Pioneer DDJ-SX?)
Because it can I use the mouse only and at work is a challenging.
Thank you for your help and advice!
geposted Wed 03 Aug 16 @ 2:54 pm
Yes it is possible. Just select a pad page on the skin and the DDJ SX pads will trigger the selected pad page.
If you want to remap your SX you can map one or two buttons to
pad_page +1
pad_page -1
geposted Wed 03 Aug 16 @ 3:22 pm
This of course I did, but the button Pioneer still run only "Sampler"
geposted Wed 03 Aug 16 @ 8:16 pm
Thats probably because you are using a Custom mapping which has to be manually updated, similar to the default one.
I am sure that if you select the "factory default" mapping from the Controllers tab of VDJ Settings, the Pads will follow the page selection
geposted Wed 03 Aug 16 @ 11:22 pm
DJdad, Thank you, I'll try to do
geposted Thu 04 Aug 16 @ 1:37 am
It works. Thanks for help!!!
geposted Thu 04 Aug 16 @ 5:38 pm
