Topic: VirtualDJ 8.2 and ASIO settings
I installed Bitdefender (virusscanner) and removed it... cause it delayed everything etc.. afterwards i looked at my settings in ASIO and i tought ? (maybe im wrong) it said on master channel 1 and 2 and 3 and 4 for headphones it know looks like this !? No choice for channels..... is it rite like this or wrong ?
geposted Fri 05 Aug 16 @ 4:46 pm
Some asio drivers name the output channels, so it's ok like that
geposted Fri 05 Aug 16 @ 5:02 pm
Sorry, i posted in the wrong place.
geposted Sun 07 Aug 16 @ 5:37 am
I have/had Bitdefender on my PC laptop (haven't renewed my license) and never had a problem with it and VDJ. It did take some getting use to the first time I installed it and unlike Norton you can't close it down (if I remember right). I have been on a MBP ("custom" Mid 09 Mac Book Pro) for about a year now tho. I still update my Acer but don't test it really as it's for "office" use and just a back up. Guess I should test it out lol.
geposted Sun 07 Aug 16 @ 7:19 am
One more question. in Pioneer uyility ASIO settings should i put it in 16 bit or leave it at 24 bit ( i mainly use mp3 files) ? Thank you
geposted Wed 10 Aug 16 @ 12:27 am
Anyone ?
geposted Thu 11 Aug 16 @ 9:42 pm
16 bit would be fine for mp3 files but if u have issues switch back to 24bit
geposted Thu 11 Aug 16 @ 10:09 pm
Leave it on default value
geposted Fri 12 Aug 16 @ 11:40 am
I think you got it right. But it you wanted your microphone added to VDJ8, you'll need different setting. What I suggest that you need to save your AUDIO set-up setting and rename.
I had my image here for viewing purposes (I did not hook my controller)
geposted Sun 14 Aug 16 @ 1:43 am
geposted Mon 05 Sep 16 @ 2:18 pm
