Topic: M-Audio Xponent Hot Cues
Hey all,
So I recently received and M-Audio Xponent. I plugged it up and almost everyone worked right away (which was awesome). The issue I'm having, though, is that I cannot get the 5 hot cue buttons to function. I know the buttons work, because when I tried to change the mapping the program recognized them. As far as I could see, I mapped everything properly. But, when I try to utilize them in a mix, they do not. I have to click the hot cue button on the screen to get anything. Any tips from the pros?
Thanks
geposted Sun 07 Aug 16 @ 1:00 pm
so if you just map those 5 buttons as ..
hot_cue 1
hot_cue 2
hot_cue 5
they still dont work ?
Btw, i see those 5 keys indeed not assigned in the default mapping. Unfortunately, we dont have this unit and too old to find one and review, so i ll wait for your feedback prior adding those to the default mapping.
geposted Sun 07 Aug 16 @ 2:59 pm
