Forum: VirtualDJ Skins
Topic: MIX Station SV_03 (4.0)
I'm trying to find the config button for this skin. Can anyone help me?
geposted Sun 07 Aug 16 @ 11:33 pm
This skin is designed for VirtualDJ 4.0, don't try and run it on VirtualDJ 8+
IF you are running it on vdj 4 then press "Options" for the config menus..
IF youre running vdj 8+ and you need to get rid of this old skin, simply close VDJ and remove the "MIX Station SV 03 (V4.0).zip" file from <user> Documents\VirtualDJ\Skins directory
geposted Mon 08 Aug 16 @ 11:43 am
