Topic: BPM Mismatch
Anyone spin jungle/drum & bass here?
I'm seeing high BPM's on different tracks....... Normally this genre is around 160bpm, in 8 I'm seeing half that (~82bpm) on a few tracks.... in 7 it was always around 82bpm...... Even in MixedInKey it analyses bpm's to ~82..... < confused >
geposted Thu 11 Aug 16 @ 1:32 pm
It's always very hard for software to judge the BPM of tracks that don't have obvious 4/4 rhythms or could be taken either way.
Even us humans can't decide sometimes. Ask a bunch of DJs what tempo dubstep is, and some will say 70, others will say 140.
It happens. Software isn't perfect. We have ears and brains, so we can decide what the tempo is. Just edit it manually :-)
geposted Thu 11 Aug 16 @ 1:43 pm
Highlight all that you think are half of their value, select x2 in the bpm editor, done.
geposted Fri 12 Aug 16 @ 5:52 am
AMAHM bpm editor won't open for multiple files,
highlight all under rated tracks and either
*2 the bpm in the tag editor
or set this script on a button, keyboard key, pad or custom button and press once.
set_browsed_file_bpm 200%
geposted Fri 12 Aug 16 @ 7:03 am
lincol2PRO InfinityMember since 2011
@ locodog
geposted Fri 12 Aug 16 @ 12:50 pm
hrdnxPRO InfinityMember since 2011
Probably off topic but can I use this on a button? "set_browsed_file_rating=5 ?????
geposted Mon 15 Aug 16 @ 12:32 am
