As you can see in the video, when saving a playlist, I can force VDJ8.2 b3343 to crash. This started last night as I was setting up for a gig. At the time, I was using build v8.2 b3324. I had tome to try this at least a dozen time and was able to repeat this process each time. Up until the day before the event, this hadn't occurred. I shut everything down and made sure to not do this action during the night and everything worked fine from that point on.
I was offline so no report would have been sent.
This seems to be a regression bug because I remember having this issue in an earlier build and it had been corrected.
My laptop is a MBP w/Retina circa 2013
Today, once back at home, I tried repeating the process and was able to repeat the crash. At that point, I decided to update my build to v8.2 b3343 to see if that would rectify the situation. It didn't. I was logged in so you should have a crash report in your archive.
The video is made with build 3343
Think the problem could be a skin issue, I reverted back to the default skin as you can see in the video.
See video here:
See video here:
geposted Thu 18 Aug 16 @ 6:55 pm
