Hi,
i can't find my list in the list of controller's to buy the virtual dj package. I just bought it second hand and the only markings i can find on it say 4play by AVE. So i'm not 100% sure if i'm searching for the right controller or not. The person i bought the controller from gave me the installation disc, without the serial numebr, for virtual dj and recommended i use it.
if anyone could recommend anything that would be great!
thanks
thanks
geposted Sun 21 Aug 16 @ 8:23 am
I'd suggest you download the latest version of VDJ 8, install it then simply plug your controller in and see if VDJ recognises it.
The fact is, if an LE version was supplied with the controller, then it should be supported in the full version.
You won't be able to use the copy of VDJ that the previous owner gave you because the software is non transferrable.
geposted Sun 21 Aug 16 @ 3:02 pm
thank you very much
geposted Mon 22 Aug 16 @ 7:12 am
This may be an old topic, but you are looking for the ME800 generic controller for the AVE 4Play
geposted Mon 18 Feb 19 @ 11:06 am
