Topic: Problem with ne Windows 10
After upgrade to the new anniversary Windows 10 version 1607 OS Build 14393.51 Virtual DJ b.3343 not working.
First error message:
And on configuration setting an error message with Pioneer DDJ Ergo-V Asio drivers appearing:
VDJ b.3343 was perfectly working with previous version of Windows 10.
Do you have any solution to resolve this issue?
geposted Mon 22 Aug 16 @ 7:31 am
Clearly the problem is with the Pioneer ASIO driver, not VDJ.
I suggest you try uninstalling the Pioneer ASIO driver, restarting your computer then reinstalling the Pioneer ASIO driver.
geposted Mon 22 Aug 16 @ 8:11 am
Also check that ERGO is not used by windows as the default playback device
geposted Mon 22 Aug 16 @ 4:17 pm
