Topic: Virtual folders
Hey,
I created a lot of virtual folders and now I want to put them in a new virtual folder called "past gigs".
Looks like I can't just drag them in. Is there another way to do this?
Thanks for your help!
geposted Mon 22 Aug 16 @ 9:28 am
stevoqxPRO InfinityMember since 2011
You can find all your gigs in C:\Users\yourname\Documents\VirtualDJ\History\
Clik on it and you see all tracks apear.
geposted Mon 22 Aug 16 @ 7:54 pm
Select the tracks from a certain date and create a virtual map (red)Drag your tracks in it.And rename your virtual map.
geposted Mon 22 Aug 16 @ 7:56 pm
hmm yeah that will work.
Thanks. sadly you can't just drag virtual folders into other virtual folders.
I hope they add that soon.
geposted Mon 22 Aug 16 @ 8:14 pm
can't you with shift held
geposted Mon 22 Aug 16 @ 8:21 pm
I tried but I can't. Thanks for the tip anyway! ;)
geposted Tue 23 Aug 16 @ 9:46 am
Yes you can!
When you drag a Virtual Folder you will need to move it a little bit towards left/right. You will see the red position marker change, indicating that the Virtual Folder will now be a subfolder of the position you drag it to...
On the above image language is Greek, but as you can see there are nested Virtual Folders inside other Virtual Folders
On this image you can see how the marker changed from a straight line to a line with an arrow. This means that the folder I'm trying to reorder will be moved inside the other folder
geposted Tue 23 Aug 16 @ 9:55 am
OMG Thanks PhantomDeejay!
That helped me a lot!
So simple I couldn't figure out myself :p
Thanks dude <3
geposted Tue 23 Aug 16 @ 10:41 am
My virtual folder doesn't appear no more in the software but every files are still there in C:\Users\(mynames)\Downloads. I worked about 8 hours for my Chriostmas party and i don't want to start it up over. Does anybody can help me ???
geposted Sun 02 Oct 16 @ 6:03 am
Where did you create your Virtual Folder ?
Typically Virtual Folders get created inside the folder you have selected when you press the "Create Virtual Folder" button.
If Top tree is selected then Virtual Folders are stored inside C:\Users\Username\Documents\VirtualDj\Folders and they appear on the tree of the browser
geposted Sun 02 Oct 16 @ 1:57 pm
