I use a Hercules RMX for mixing in VD7 currently. I have a button that loops at 2 beats then buttons assigned to double of half that.
In VD8, I don't see an option to select a 2 beat loop but only what was last used. For example, if I set the loop beat to 2 beats and enable it, start to half the beats for a climax then release the loop, that loop I still on 1/4 beat. Unless I manually change it, when that loop is engaged, it will engage at 1/4.
Is there a way to do this differently or change it so the control reflects what I can do in VD7?
Thank you.
Thank you.
geposted Thu 25 Aug 16 @ 5:16 pm
loop 2
you can call any length loop by including a parameter [I use, loop 1.5 with slip on quite often]
geposted Thu 25 Aug 16 @ 5:37 pm
[quote=locodog
I use, loop 1.5 with slip on quite often][/quote]
As loop above I tried the slip on and OFF and off I see/ hear no difference, what suppose to happen?
geposted Thu 25 Aug 16 @ 6:42 pm
slip or slip mode?
I meant slipmode,
loop 1.5 is one of those lengths that [on paper] the 4/4 brain recoils in horror from but actually [in practice] is used quite a bit in production to funk up monotonous 4/4 beats [best results with breakbeats jungle etc]
another length is loop 0.33 [giving you a triple over a single beat]
I meant slipmode,
geposted Thu 25 Aug 16 @ 6:58 pm
yes, with slip mode on.
geposted Thu 25 Aug 16 @ 7:10 pm
Slip mode can be a tricky one as it works in a two ways
if you turn it on already in a loop, it only slips when scratched
if it's on before you are in a loop, upon exiting the loop then it jumps to where you would have been had you not looped
geposted Thu 25 Aug 16 @ 7:16 pm
ok thanks
geposted Thu 25 Aug 16 @ 7:21 pm
Thanks for the info. I forgeot about the VDJ script.
geposted Wed 31 Aug 16 @ 4:33 pm
It's all script, controllers, skins even then some pluggins, very little happens in vdj without a script
geposted Wed 31 Aug 16 @ 5:09 pm
