Topic: completely ignore deck 3 and 4
i have a pioneer ddj sr, and i ONLY use 2 decks, deck 1 and 2,but sometimes my hand presses the 3 and 4 button my mistake.and those decks become active, although im using a 2 deck skin... i want an INIT script or something to deactivate deck 3 and 4 at startup,or a script to quickly unload deck 3 and 4 if it loaded my mistake.
i have already tried deleting the shortcut of the 3 and 4 button,in fact it cant delete because the four buttons are mapped to one action.thanks in advance
geposted Fri 26 Aug 16 @ 3:16 am
I don't see a licence for your SR controller. What version of VDJ are you using?
I know the issue, but there is no solution for this. At least none that I know of.
geposted Fri 26 Aug 16 @ 10:14 am
