hi guys and gals
i wanted to ask when you analyse a track it doesnt allow you to analyse certain options
for example
say i want to just analyse the key nothing else
is it possible ?
when i plug my dj controller in and i modify it
can i save and export my midi controller map ?
thanks
for example
is it possible ?
thanks
geposted Sun 28 Aug 16 @ 2:28 pm
No, it's not possible to split up the track analysis. It only takes a split second anyway, why would you need to only partially analyse?
As for mapping, as soon as you modify the default mapping, it gets saved as a separate file. Why do you want to export it?
geposted Sun 28 Aug 16 @ 5:28 pm
