Hi guys, any help or input would be great. I've mapped a few visualizations to keys to make jumping from camera to lottery or telly visuals quick and easy. The problem i have is i can't map any of their effect_button options, the option is there but nothing happens. I can map audio effects but not the video ones?
Thanks guys
Thanks guys
geposted Sun 28 Aug 16 @ 9:08 pm
effect_button 'Lottery' 3
working here, can you give examples of what you have tried.
geposted Sun 28 Aug 16 @ 9:38 pm
I have exactly that written and nothing happens. Yet it works with audio effect_buttons. Its very strange.
I've tried mapping it to a keyboard and a launchpad but nothing. I've tried lottery/camera and slideshow but none of them trigger. Yet it i did the same for echo it works instantly.
What i'm try to achieve is that on lottery when its activated that i can use a keystroke or pad press to activate the Start/Stop button situated in the effect_button 1. But it just won't work for me. Id love to see how you got yours working.
Thanks for the reply BTW. appreciate it
geposted Mon 29 Aug 16 @ 12:41 pm
Okay i got it working. thanks.... i had left out deck master from the start of the VDJscript.
Thanks again for the help
geposted Mon 29 Aug 16 @ 12:53 pm
If you loaded these effects on master, you probably want to use
deck master effect_button 'Lottery' 3
Otherwise it will take the Lottery instance on the deck it is called from/active deck, which probably doesn't have a Lottery effect running.
geposted Mon 29 Aug 16 @ 12:56 pm
Ok I have no idea how this works, nor slideshow. Can't find info on how to set up.
geposted Mon 23 Apr 18 @ 12:37 am
Ok I have no idea how this works, nor slideshow. Can't find info on how to set up. I'm On a Mac Book pro.
geposted Mon 23 Apr 18 @ 12:39 am
Both need a folder with images (or videos for Slideshow). To define this folder, you need to open their GUI from the small cog icon you see next to the Effect when you open the Effects drop selection list.
geposted Mon 23 Apr 18 @ 11:55 am
