Topic: Script whenever a song is loaded
Hello,
I'd like to write a script that executes every time a song is loaded into a player. But I can't find the place to write it (the "load event" so to speak).
I was able to find it for my controller, when I use the LOAD A / LOAD B buttons, but I'd like it also to work when I drag-and-drop a song into a player. Where is the event for this?
Thanks!
geposted Tue 30 Aug 16 @ 9:27 am
Use a repeat start script at around 100ms to query 'load pulse'
geposted Tue 30 Aug 16 @ 2:49 pm
Thanks locodog,
Where can I create a repeat start script?
geposted Wed 31 Aug 16 @ 1:17 pm
I think you'll have to do write it in the ONINIT key of the keyboard or controller mapping if you want it to start automatically.
Or map it to a button and press the button once each session to activate the script.
It'll then run in the background until you close VDJ or exit the script with a repeat_stop script.
I'm by far not the best repeat start/stop scripter but it should be something like this:
repeat_start_instant "myScript" 100ms & load_pulse ? "DoWhatYouIntendToDoHere" : "MayBeDoSomethingElseOrNothingHere"
To stop the script just call
repeat_stop "myScript"
geposted Wed 31 Aug 16 @ 3:05 pm
Yep pretty much that except load_pulse works the other way round, it is normally true and briefly [200ms] goes false when triggered
you should revert your loading scripts on your controller as, load pulse covers all loading events
geposted Wed 31 Aug 16 @ 3:49 pm
