Topic: Search Sort buttons gone
bnrentPRO InfinityMember since 2015
On the left of the files area I use to have three button one for Karaoke, Music and Video to sort my search results. it was nice because it was easy and fast with them there, but now they are gone. Were can I go to get them back. Please anyone?
geposted Thu 01 Sep 16 @ 12:22 am
3 questions,
What build are you on, what skin, and what o/s?
geposted Thu 01 Sep 16 @ 12:37 am
To be honest not sure what all you asked....I am using the original Skin Default with Two Deck. Same as always. No even sure at what point it went Away as I was starting to play more with filters, loops and things. I could say it happen after last update which was maybe two weeks back. I am on 8.2
geposted Thu 01 Sep 16 @ 12:53 am
ok, mac or pc?
and if you go into config at the very bottom left hand corner of the config window you'll see your build number, starting
V8,2 b[a number]
geposted Thu 01 Sep 16 @ 12:57 am
sure don't want to look stupid here though that may be to late...I am running windows and virtualdj8 8.0.2245.0.....hope that was it
geposted Thu 01 Sep 16 @ 1:55 am
I didn't say but its windows 10
geposted Thu 01 Sep 16 @ 1:58 am
8.0.2245.0 is a old build [very old, 06 May 15]
current public build is 3343
updating is recommended
geposted Thu 01 Sep 16 @ 2:49 am
The 3 buttons only appear if you change the "showOnly" option.
You can find it by clicking on this little button and choose it from the menu.
Alternatively you can find this option in the settings too.
Just change it to something else as the default value and the buttons will reappear.
geposted Fri 02 Sep 16 @ 9:00 am
got it thanks
geposted Sun 04 Sep 16 @ 6:00 pm
