Topic: Quartz Compositions
In the change log for Build 3378 it says that support for Quartz Compositions as video effects on Mac is now supported, I don't see it under video effects and if it is there how does one activate them? Thanks.
geposted Fri 02 Sep 16 @ 2:51 am
You have to move them there if you have any.
Do you know what a Quartz Composition is???
Um yeah I know what they are, been using Mix Emergency for years. What do you mean you have to move them there?
Move them to the vdj folder.
Thanks got them loaded. I have audio reactive QC files, is there a way to get them to work with the audio?
That depends on where the QC gets it's audio from. I've you've got a composition you can share, I can have a look and see what is required. If you're using it in ME then I suspect the input is AudioSpectrum1 which isn't implemented just yet but is on the todo list.
SBDJ, I will PM you a link to one of them. More than likely the input is AudioSpectrum1. The QCs that I have came from ME itself and I Love QC.
On another note and it may be in the works, but if the QCs could be loaded and played automatically through the slideshow plug in like ambients that would be awesome.
Lol, ok my bad. Some cats dont understand them.
Anyways what I've done is created a folder within my video plugins folder and just named it "QTZ".
I put all my quartz files in there. Now when I open VDJ I can click on that folder and start my quartz.
I mainly use it for FlyBoost, instagram/twitter feeds.
Epic quote fail. Please delete.
Country Boy wrote :
[quote=the SOUND INSURGENT]You have to move them there if you have any.
Sorry I did come off like an ass. Had hernia surgery yesterday and was chilling on the computer.
Hijacking my own thread here LOL. If you like Flyboost you should check out JammText. Works awesome with any video program.
https://www.mixcityinc.com/jammtext.html
All good bro.
Yeah Vince called me last week so ill probably test it out this weekend.
