all of a sudden, I can't copy & paste items in the tag box...also won't let me save artwork..using win10..when I restart it works 1 time..then stops..any suggestions?
geposted Tue 06 Sep 16 @ 4:09 am
What version of VDJ you using ? There was a version (don't remember anymore) that had this problem but it's been long fixed.
Try out the early build version (newest build).
http://www.virtualdj.com/download/build.html
geposted Tue 06 Sep 16 @ 4:28 pm
mine was doing that in the pass 2-3 update on my mac they said try shortcut off the keyboard.... if you use the shortcut a couple times then the pad or mouse works.or trying going back to VDJ-8 skin then back to VDj-8+ skin
geposted Tue 06 Sep 16 @ 5:16 pm
