Cool we got there.
geposted Tue 03 Apr 18 @ 3:50 am
I know this thread is old and a solution for effects on mic is available, however when you compare ''mic fx'' to running your mic into a deck and using the deck effects the mic sounds cleaner. Also for those controllers that don't have mic eq this is perfect, being able to cut some bass or add mid and hi.
Please consider this request. All that's needed is when mic is selected in the Audio Preference Input tab the user has two choice on the GUI, auto or manual bpm. If line is selected as input for running cdj the bpm would revert to how it currently works live bpm.
geposted Thu 30 May 19 @ 4:08 pm
