Topic: BUILD 3398 BPM ISSUE
Hi,
i use vdj with a partition on my macbook pro (15 mi-2012.)
Processeur : 2,3Ghz Intel Core i7
Memoire : 8Go 1600Mhz DDR3
Nvidia GeForce GT650M 512Mo
My settings is Two Reloop RP7000 and and Djm S9
I can not really understand where it comes from. One of the recurring problem I have is that when I use the timecode with my turntables , the left deck BPM vary too much . so I can not make long transition because the song will not been beatmatch too long .whereas if I use one deck to internal mode , the BPM will be stable. what could cause this issue.
I made a video to show the problem. Do others meet the same issue???
https://youtu.be/zsGvyCE0JLU
geposted Sun 11 Sep 16 @ 6:42 pm
