Topic: Kontrol S2 master Output
DjHANJAPRO InfinityMember since 2015
I was using a Pioneer DDJ-SX but have had to change to my Kontrol S2 for a little while but the master output is super low compared to the SX. With the SX I ran the master volume in the software and the controller at around 50% and the limiter at -3db. However with the S2 I have the master in the software at 100% and the controller at near 100% and changed the limiter at the default setting rather than minus 3db and the output still isn't that loud. This means I have read line the controller with no head room when playing live.
Is there anything else I could do in the software to increase master signal without clipping etc. Is there a way to increase the master out without affecting audio quality?
geposted Mon 12 Sep 16 @ 3:19 pm
Unfortunately, no.
You have maxed everything on the "digital" domain and everything else would introduce distortion, or would alter the dynamic range of your songs.
I would suggest you to use a hardware EQ after your console to boost the pre-amp signal and restore all other settings back.
geposted Mon 12 Sep 16 @ 4:01 pm
