Topic: Camera plugin ???
Just been helping somebody with their video input device and advised them to use the camera plugin (which they got working)
BUT I just went to my setup and the camera plugin isn't there.
I'm on a fairly recent install of windows and I'm using a recent build of virtualdj8.2 but it looks like the camera plugin isn't included now.
is there anyplace I can get this as ive done a search in the downloads section but its not there either :(
EDIT: its now in the Visualisations section.
EDIT2: there is no option to select which device it will use (if for example you have more than one camera or capture device)
geposted Fri 16 Sep 16 @ 1:01 am
I know of 2, one in the add on essential media and the other is in the add on telly media.
There should be a knob in the plug in that says camera. When another source is available, if you turn the knob the other source can be selected.
Hi chaps simple question is there a zoom option as i cant see 1 using Logitech web cam
