Topic: Reverse effect for 8.2
How do I get the reverse effect for 8.2
geposted Fri 16 Sep 16 @ 5:35 pm
Just map / remap a button to "reverse"
Alternatively you can do a SLIP Reverse by using "dump"
geposted Fri 16 Sep 16 @ 5:46 pm
AsTheDJPRO InfinityMember since 2008
or try "dump while_pressed"
geposted Fri 16 Sep 16 @ 6:36 pm
thanks you guys are awesome
geposted Fri 16 Sep 16 @ 8:25 pm
