Topic: DDJ WEGO2 Mapping
Hi hope somebody can help, I have just changed my controller to a WEGO2, for some reason when I try to change the mapping of some buttons nothing happens. The settings are correct on the new mapping on VDJ itself but the buttons still does the default not what I have changed the mapping too.
For example i'm trying to change FX4 button to seek +8 & and the FX3 button to seek -8, its always worked fine with previous controllers and if I plug my Denon MC4000 Controller in changing the mapping still works fine.
I am using VDJ 8.2 on WIndows 10 with an Infinity License.
geposted Sun 18 Sep 16 @ 1:39 pm
Quick update, I have tried this on another machine and it's the same issue.
I have tried changing different buttons instead of the FX ones (e.g. Hotcue ones) and they will programme no probs.
It just seems that I can not re-map the FX buttons, any help would be great Thankyou everyone.
geposted Sun 18 Sep 16 @ 4:33 pm
Just tried with the WeGO (not WeGO2) and everything seems fine here. Are you sure you map the FX3/FX4 and not some other Keys like JOG_FX ?
geposted Mon 19 Sep 16 @ 7:54 pm
Same Problem with the new MCX8000, Mapping command seek +8 and seek -8 have no function.
Any Ideas?
geposted Fri 23 Sep 16 @ 7:11 pm
