Topic: Clean Install of VDJ 8.1 to 8.2
Im trying to do a clean install, And encountered many problems..
First problem I encountered was "The feature you are trying to use is on a network resource that is unavailable". That one is sorted now, I sorted it through deleteing VDJ related stuff in the regedit.
Now on re install I'm encountering " The Older version of Virtual DJ 8 cannot be removed. Contact your technical support group."
And yes I've followed the steps here. http://www.virtualdj.com/wiki/PC%20Clean%20Re-install%20VirtualDJ%208.html
I'm on Windows 10, aswell.
geposted Sun 18 Sep 16 @ 8:53 pm
One thread is enough, please don't cross post.
geposted Sun 18 Sep 16 @ 9:20 pm
Please do not double post, and keep all feedback in your previous post, about the same issue.
Closed as duplicate by AMAHM
geposted Sun 18 Sep 16 @ 9:37 pm
