Topic: Led Mapping for vinyl mode button
it seems like on the ddj sr's mapping, the vinyl mode led mapping has been left out...basically,for example,with the keylock led, when u turn off the master tempo from the skin itself, it corresponds on the controller as the led is off...whereas with the vinyl mode,it does not work like this...if u press vinyl mode on controller , the led is on meaning scratch mode,but if u change it to nudge mode in the skin itself,the vinyl led still is on.... when looking at the default mapping,there is nothing related to and led for the vinyl knob,so i tried adding <map value="LED_VINYL" action="vinyl_mode" /> in the mapper xml file..without any success.
geposted Thu 29 Sep 16 @ 10:08 pm
The LED of the Vinyl button is a Hardware one, meaning that its controlled from the unit and no Midi Out (LED) is offered. So its a firmware limitation and not a mapping issue. In this case, you will have to use the VINYL button from the actual unit to toggle between Vinyl and Bend mode.
geposted Fri 30 Sep 16 @ 10:09 am
ok, had a feeling so..anyway thanks.
geposted Fri 30 Sep 16 @ 11:50 am
