Using a Mixtrack 3 on a mac mini running EL Capitan & VDJ 8 Pro Infinity. I depress the wheel button on the mix track and it should activate vinyl mode for scratching. However, pushing the wheel button only pauses the music, odd.
The wheel button lights up meaning it's active or in "vinyl mode" but unable to scratch. absolutely no control of the waveform with the jog wheel. tried several combinations on the customizable setting/options menu to no avail. Is it me, the mixtrack or the software?
geposted Fri 30 Sep 16 @ 2:07 am
You already have a thread running here :)
http://www.virtualdj.com/forums/212869/VirtualDJ_8_2_Technical_Support/Got_an_Itch___Can_t_Scratch.html
geposted Fri 30 Sep 16 @ 7:35 am
