i pay for my numark nv controller twice on monthly subscription but still getting 10 minute please sort it out or send my money back in my account
geposted Sat 01 Oct 16 @ 12:42 pm
You're logged in to VDJ 8 with your forum user name and password?
geposted Sat 01 Oct 16 @ 12:48 pm
and make sure in settings.......
geposted Sat 01 Oct 16 @ 2:09 pm
DontLogin setting should be actually set to "NO", not to yes...
DontLogin setting active (set to yes) means that if you are not logged in VirtualDj will NOT ask you to login!
geposted Sun 02 Oct 16 @ 2:27 pm
Those settings should really be reworded because alot of them are hard to understand.
Some say set to "true" when the check boxes actually say "yes" or "no"......
I've asked about this when v8 first came out.
geposted Sun 02 Oct 16 @ 2:33 pm
True=Yes and False=No
That's common sense even for people that don't know English very well.
Apart of that, all settings use "Yes" / "No" now. Inside settings there's not a single setting that uses "True/False"
There are 5 settings (if I remember correctly) that use on / off, but that's because they also have other possible values as well.
Edit: And BTW these settings belong to the "advanced" settings category. Normally the "DontLogin" setting reflects the "Don't ask again" checkbox on the login window, which I believe it's worded very well! :)
geposted Sun 02 Oct 16 @ 2:46 pm
