Topic: 8.2b3420 sound issues
Just upgraded v8.2b3420 and now my audio is all distorted like it would be back when we had the performance slider and it was out of whack. Is this a known issue with a fix or am I just lucky?
3GHz Win7 machine with 8G RAM
Screenshot shows sound card and setup, which is all correct and has worked fine till now.
geposted Mon 03 Oct 16 @ 8:32 pm
Update:
Restarting the PC seems to have fixed the issue. This is the first update that required a system restart and I'm on early release updates.
geposted Mon 03 Oct 16 @ 8:54 pm
2 ms latency is quite low
It would be easy for any background operation to interfere with that
geposted Tue 04 Oct 16 @ 5:13 am
