Hello , I just have the last update b 3420 VDJ 8.2 , and the mapping functions doesn't work correctly in the CDJ Nexus 2 . is not showing the Counter and Jog wheel center runing, hot cues, etc I really would appreciate your help please , fixing this problems. Thank you.
geposted Mon 03 Oct 16 @ 9:06 pm
have you updated your firmware?
geposted Mon 03 Oct 16 @ 9:07 pm
Hi Locodog , thanks for answer so fast , im gonna try with your recommendation , Actually i have the Firmware version 1.20 in my Nexus 2
geposted Mon 03 Oct 16 @ 9:27 pm
1.50 is current
geposted Mon 03 Oct 16 @ 9:56 pm
Yes, newer builds of VirtualDj support latest firmware of NXS2 (1.4 & 1.5) which allows them to show the full waveform on screen.
However these firmware versions brake backwards compatibility.
Long story, short: Just update to latest firmware and not only your NXS2 will work correctly again, but they will also show the full waveforms on screen! :)
geposted Mon 03 Oct 16 @ 10:05 pm
Thank you very much guys !, I did the Firmware update to 1.50 & everything works great again!
geposted Tue 04 Oct 16 @ 12:42 am
