Hi can you help me how i can make my cue to be just like on v7.When is on pause to make new cue or change the last cue,i wont to be just like on version 7.
Thanks and sorry for my bad English.
geposted Wed 05 Oct 16 @ 9:38 am
look through options there are a several different cue settings you can change also the manual should cover it all even better if its in your native language :-)
geposted Wed 05 Oct 16 @ 10:24 am
I try all options but not one of them not work like as version 7,even I tried options from another topic but none of them and does not work as Version 7
geposted Wed 05 Oct 16 @ 12:23 pm
I had posted this elsewhere, but here you go again:
Remap your cue button to:
play ? cue_stop : cue ? cue_stop : param_equal get_cue 2 ? set_cue 2 & goto_cue 2 : param_equal get_cue 3 ? set_cue 3 & goto_cue 3 : param_equal get_cue 4 ? set_cue 4 & goto_cue 4 : param_equal get_cue 5 ? set_cue 5 & goto_cue 5 : param_equal get_cue 6 ? set_cue 6 & goto_cue 6 : param_equal get_cue 7 ? set_cue 7 & goto_cue 7 : param_equal get_cue 8 ? set_cue 8 & goto_cue 8 : set_cue 1 & goto_cue 1
geposted Fri 14 Oct 16 @ 12:10 am
One big thank you
geposted Mon 17 Oct 16 @ 9:26 pm
