Topic: Virtual dj 8 - Page: 1
Program stops running after ten minutes also won't login with out wifi
geposted Wed 05 Oct 16 @ 3:49 pm
If the program stops after 10 minutes you're probably not logged in,
tick the don't log out option, connect your machine to the internet one time using rj45, or phone tethering , log in and never log out again
by the way one thread is enough please don't cross post.
geposted Wed 05 Oct 16 @ 3:54 pm
My bad
geposted Wed 05 Oct 16 @ 4:04 pm
I never logged out but each time I open my laptop and then open virtual dj using pioneer sb mixer it ask me for,login name and,password
geposted Wed 05 Oct 16 @ 4:09 pm
Do you have "remember me" selected?
Are you only using the one computer, or do you also use VDJ on others?
geposted Wed 05 Oct 16 @ 4:31 pm
Try this option
geposted Wed 05 Oct 16 @ 4:32 pm
I have other computers with vdj7 that use numark with. And yes there is a remeber me selection also don't ask again,selection
geposted Wed 05 Oct 16 @ 5:09 pm
How many versions of Virtual DJ do you have open, and logged in at the same time?
geposted Wed 05 Oct 16 @ 6:19 pm
3
geposted Wed 05 Oct 16 @ 6:37 pm
taylaPRO InfinityMember since 2007
I think maximum is only supposed to be two, but don't quote me on that... now I got to go write this three more times else where as apparently exact same problem is happening to three other guys.
geposted Wed 05 Oct 16 @ 6:49 pm
Just an update, it's seven people that have the same problem, Christ, I'm not gonna get any sleep tonight.
geposted Wed 05 Oct 16 @ 6:52 pm
Is that right and I have 2vper lap top
geposted Wed 05 Oct 16 @ 7:00 pm
Also I'll try that remember me setting but if,that does not work can I get my cash back
geposted Wed 05 Oct 16 @ 7:05 pm
You can only have 2 open at the same time. If you try to open a third version, it will sign out of one of the other two. What software company do you know of that gives refunds?
geposted Wed 05 Oct 16 @ 7:51 pm
This one if the program won't work
geposted Wed 05 Oct 16 @ 9:16 pm
One says don't ask again the others says this is a public or shared computer do not remember me
geposted Wed 05 Oct 16 @ 10:35 pm
I found the option to stay logged in
geposted Wed 05 Oct 16 @ 10:44 pm
The option you were shown 6 hours ago?....
geposted Wed 05 Oct 16 @ 10:52 pm
Change log in to Microsoft problem solved thanks
geposted Wed 05 Oct 16 @ 11:17 pm
virtual dj stop after ten min asking me to register my name online can you some one help me with any information on this
geposted Fri 07 Oct 16 @ 11:52 am
95%
