i noticed this last week and iv done the new update now and for some reason Played Sets doesnt appear in My Sets
geposted Sat 08 Oct 16 @ 4:22 pm
your talking about history?
otherwise I have no clue what you mean.
geposted Sat 08 Oct 16 @ 4:52 pm
yes send history. for some reason, it does send to my home page
geposted Sun 09 Oct 16 @ 2:34 pm
ok so i assume you have the option turned on.
sendHistory-> yes
you may also check historyDelay default is 45 seconds. if something is shorted then this setting its not logged.
i believe line volumes must be over 10% as well for it to get logged.
is you computer connected to the internet when djing? not sure if history will send later maybe one of the devs can let us know.
sendHistory-> yes
geposted Sun 09 Oct 16 @ 3:17 pm
everything is on and double checked... have my seconds delay set to 5 seconds... volumes is set at max and yes computer is connected to the net
geposted Tue 11 Oct 16 @ 6:00 am
