Topic: VDJ8 Auto BPM
andyp85Home userMember since 2012
I think 'Auto BP<' would be the correct title for this.
Whatever I try to do/change in the Config I just cannot stop one deck matching the other bpm on the other deck.
Also at times when one deck has say a file at 120 bpm .. if I Ioad a file at say 129 it changes to the previous tracks bpm of 120?
My Config settings are on both decks do not have 'Smart Play'
'Auto BPM' is set to 'No'
Have used VDJ 7 for some time now with no issues.. and want to start using VDJ8 with a controller but at the moment this is driving me crazy trying to work this out.
Have looked on the net and on this forum but with no luck.
Thanks
Andy UK
geposted Sat 08 Oct 16 @ 10:28 pm
I think I have answered this myself...
Had to enable 'Rest pitch on load' to 'Yes'
Quite why this is set to 'No' for the default seems very odd to me??
geposted Sat 08 Oct 16 @ 11:20 pm
Imagine you have hardware then it makes sense
geposted Sun 09 Oct 16 @ 12:49 am
Will consider this again then when I get the controller... :)
geposted Sun 09 Oct 16 @ 6:25 pm
Yeah when you pay $1100 for a controller you will turn Auto everything off... at least I did
geposted Mon 10 Oct 16 @ 6:48 am
