Topic: Undocumented scripts
I've spotted new syntax for some scripts that aren't documented
The one's I've spotted
effect X active
[seems straight forward X being the slot]
var 'varName' X ?
[In place of var_equal X, will this accept actions?]
Are there any more?
geposted Mon 10 Oct 16 @ 12:11 pm
effect X active is basically ver 7 syntax which for backwards compatibility is still valid.
The ver 8 equivalent syntax is effect_active X where X is indeed the FX slot #
var 'varname' X is equivalent to var_equal 'varname' X so you query if the variable with name varname has value X
geposted Mon 10 Oct 16 @ 1:01 pm
