Forum: VirtualDJ 8.1 Technical Support
Topic: Crossfader skipping
MrviperXControlleristMember since 2014
every time I try to use the cross fader it doesn't slowly increase it either jumps to deck 1, middle or deck 2 any ideas how to fix this ? would be highly appreciated
geposted Sat 15 Oct 16 @ 12:28 pm
What controller are you using? What skin are you using?
Have you tried changing the crossfader curve (details in the manual)?
geposted Sat 15 Oct 16 @ 10:56 pm
DDJ SX2 Pioneer. Ive not changed anything it was working perfectly then this happend randomly
geposted Sun 16 Oct 16 @ 3:14 pm
