Topic: Numark Mixtrack Pro 3 Deck 2 right won't play music through the speaker HELP!
No idea but the first deck (left) will play music through the speaker just fine. Please help. Thanks
geposted Sun 16 Oct 16 @ 1:27 pm
audio config picture please.
geposted Sun 16 Oct 16 @ 2:03 pm
What do you mean by that where can I find it?
geposted Sun 16 Oct 16 @ 2:05 pm
From VirtualDJ Settings-->AUDIO tab, click on the special Numark Mixtrack button you will see in the CARD section. This should create an audo configuration like..
Master ... Numark sound card .. Chans 1,2
Headphones .. Numark sound card .. Chans 3,4
Your speakers need to be connected to the Master Output socket at the rear panel of the unit in this case.
If for any reason you still have audio routing issues, please make sure.the Numark sound card ..
- is not the default sound card of your Operating system
- is properly set to Quadrophonic (4 speakers) http://www.virtualdj.com/wiki/Pre-listening%20with%20headphones%20with%20Sound%20cards%20without%20ASIO%20drivers.html
geposted Sun 16 Oct 16 @ 2:08 pm
