Topic: Reorder samples
Greetings. I loaded a few of my custom samples onto a custom sample bank and made it the default bank in settings. Confusingly, when I rearrange my samples by moving them to the order I want, the order reverts back when I restart the program. Is this normal? My samples are wavs. They play fine otherwise.
geposted Sun 16 Oct 16 @ 7:38 pm
I figured it but it was counter intuitive. I had to reorder the samples on the side menu instead of the main center menu then it worked.
geposted Sun 16 Oct 16 @ 8:01 pm
