Topic: Map 8 pads for each deck
NuzzletPRO InfinityMember since 2015
I have two sets of 8 pads, I want 8 to control left deck pads, and the other 8 to control deck right. But the pad pages apply to all pads, so how can I get these pads to act independently controlling their own decks? I have all the pads on the left side mapped to "Deck left pad #", and deck right for right. When I change the pads page, it changes it for both. When I use one of the pads, it controls the active deck, not the deck specified.
geposted Mon 17 Oct 16 @ 1:36 am
Remove 'deck left' and just map as 'pad x' and it will use the deck it was triggered from.
geposted Mon 17 Oct 16 @ 6:16 am
the deck it was triggered from?
geposted Mon 17 Oct 16 @ 3:15 pm
Are you using a natively supported controller or one with a custom definition ? In case of a custom one, how are these Pads/buttons are defined in the definition ?
geposted Mon 17 Oct 16 @ 3:19 pm
<button note="36" name="Pad 1" />
I actually have 64 pads in total, its not a launchpad, but similar. Do I need to add deck=left/right on the pads?
geposted Mon 17 Oct 16 @ 3:37 pm
If the unit doesnt have obvious sides, it makes sense not to define any deck="" in definition.
So ,
deck left pad 1
and
deck right pad 1
in mapping file should work independently .
I suppose the one on the Right side is not named as Pad 1, right ?
geposted Mon 17 Oct 16 @ 4:18 pm
Here are the mappings for each sides first pad
<map value="Pad 45" action="deck right pad 1" />
<map value="Pad 41" action="deck left pad 1" />
Plus,
deck left pad_editor
deck right pad_editor
are the same page.
Will I have to create different pad pages for each deck?
geposted Mon 17 Oct 16 @ 5:58 pm
I actually solved my problem. It had to do with how I changed the pad pages. Anyway, user error, my fault. Just a mistake. The help was useful though on accomplishing a few other things, so thank you for your time.
geposted Mon 17 Oct 16 @ 8:24 pm
Why don't you just say what it is? You've mentioned it in other posts already.
It's an Ableton Push controller.
geposted Mon 17 Oct 16 @ 8:56 pm
