Topic: Numark Mixtrack PRO II and USB Headphones
beermattControlleristMember since 2015
I have a Numark Mixtrack PRO II, which works well on its own with "normal" stereo headphones through (current) VDJ. I also use VDJ with some USB headphones when tagging tracks, sorting playlists, etc. when I'm on the sofa. Again, this works fine, with VDJ seeing the headphones as an external USB sound card, and I can output master to the laptop speakers if I want to.
I wanted to swap the 3.5mm headphones I use for the USB headphones when using the Mixtrack PRO II, so I have MASTER set to Mixtrack PRO II (Chan 1&2), and HEADPHONES set to USB sound card (Chan 3&4). Result: no output through headphones.
Have I missed an obvious setting, or is this a simple no-can-do?
geposted Tue 18 Oct 16 @ 1:02 pm
99,9%:
You need to set:
Master: Mixtrack PRO 2, chans 1+2
Headphones: USB Audio, chans 1+2 as well!
geposted Tue 18 Oct 16 @ 1:13 pm
PhantomDeejay wrote :
99,9%:
You need to set:
There you go. I knew there was a simple "make it work" setting that I hadn't tried! Thank you!
geposted Tue 18 Oct 16 @ 5:03 pm
