Topic: NV et virtualdj 8.2.b3440
fbqusebControlleristMember since 2013
bonjour je ne sais pas vous mais cette version buggue avec le contrôleur NV, le logiciel freeze......§ avez vous déjà eu des remontés pour mauvais fonctionnement? finalement je suis revenu à la version 8.0.2438....dommage car sans NV la version beta est super!
geposted Tue 18 Oct 16 @ 5:11 pm
Please write in English or use the French Forums.
The NV had an issue in the latest build, but a fix is provided in the latest Early Access build (3456).
Open VirtualDJ , goto Settings and from the OPTIONS tab set the setting EarlyAccessUpdates to Yes.
Close and re-open VirtualDJ, wait for the new build to be downloaded, Click Yes.
geposted Tue 18 Oct 16 @ 6:19 pm
Hello,
I followed your advice, I restarts the software it asks me if I want to do well an update to Early Access build (3456) i answer ok but strangely, the software will not install. At each start it asks if ok for updating etc .... it's looping but does not install the update.
geposted Wed 19 Oct 16 @ 2:56 pm
To be sure that this does not come from the antivirus or firewall I've stopped hanging down the update.
geposted Wed 19 Oct 16 @ 3:00 pm
Dont connect the NV.
Delete the ready file you will see in VirtualDJ/Cache folder
Start VirtualDJ , wait for a while and try to update again
geposted Wed 19 Oct 16 @ 5:07 pm
So it does not pass anything ....
geposted Thu 20 Oct 16 @ 8:10 am
hello,
I look forward to the 100% compliant version with the NV controller is it coming soon?
geposted Sat 22 Oct 16 @ 7:46 am
geposted Sat 22 Oct 16 @ 9:46 am
Hello,
Thank you for the link, I am trying to test this version is great ..... thank you.
geposted Mon 24 Oct 16 @ 8:02 am
merci de votre aide chers collegues mais mon controlleur es le nvII
JE CHERCHE LE MAPPING POUR CELUI CI SVP
geposted Thu 27 Oct 16 @ 10:38 am
