Topic: Search Feature
dbrosPRO InfinityMember since 2009
I am experiencing an issue with the Search feature. Seems like when I do initial searches they take forever. After a few searches everything seems fine. I've been using this program forever and this problem doesn't exist with other builds. Not sure if something was changed with search for this new build. I am running Windows 10 Pro; Intel Core i7-3632QM CPU @2.20 GHZ; 16GB RAM, 64 bit operating system.
geposted Fri 21 Oct 16 @ 11:47 am
Is file date one of your fields in the browser if so turn it off, use first seen
geposted Fri 21 Oct 16 @ 12:25 pm
I believe it is. I will check later. I hope it is that simple. Thanks for the tip
geposted Fri 21 Oct 16 @ 3:59 pm
