Topic: American Audio Vms2 buttons stopped lighting up
Hello looking for some thoughts. I have an American audio vms2 that I was using to run my stanton str8150's. Worked fine for several weeks with no problems. For some reason when I turned it on the other night none of the buttons would light up. Its also weird that even when I turn the power switch to off the red light on the power switch stays on. The functions of the controller still work just no lights. I running vdj8 and Windows 10. Any thoughts would be appreciated.
geposted Fri 21 Oct 16 @ 1:52 pm
VMS2 can operate as MIDI even without connected to the power adaptor, meaning that the unit is USB powered as well.
Can you also test on another computer ? Could be a hardware fault so most likely you need to contact with American Audio
geposted Sat 22 Oct 16 @ 9:42 am
