I've picked through literally every setting I can find, and can't figure out how to disable this. When I cross fade it either plays or pauses the track you're fading to. Anyone have advice?
geposted Tue 25 Oct 16 @ 8:21 pm
faderStartStop perhaps?
Not sure if that's for the volume faders only but worth a check anyway.
geposted Tue 25 Oct 16 @ 8:37 pm
Nope didn't fix it. ugh this is frustrating. My license expires in 2 days, it doesn't do this in Traktor, but i'd rather not switch
geposted Tue 25 Oct 16 @ 8:53 pm
Does this happen without the controller?
geposted Tue 25 Oct 16 @ 8:59 pm
It doesn't do it when using my iDJ3 or just using keyboard and mouse. It's something with the mapping or the controller
geposted Tue 25 Oct 16 @ 9:03 pm
Which controller?
Try resetting the mapping to default and see if that helps.
geposted Tue 25 Oct 16 @ 9:11 pm
Using a Numark 4trak. It's at default settings. Just figured out if I delete the CUE from the mapping it won't do it. So something is causing the cue to activate when crossfading.
geposted Tue 25 Oct 16 @ 9:15 pm
OMG, i'm an idiot...there is a hardware button on the front of the mixer that makes a track auto play when crossfaded to. Thanks for your replies guys! I shall of course be renewing my sub! Best community out there, thanks again
geposted Tue 25 Oct 16 @ 9:20 pm
