Forum: Music discussion
Topic: Alternative to RMX 500?
Hi, I have DDJ WeGo and. VDJ8 in my Mac. I love the idea of RMX500 but can not aford it. Would there be a cheaper option for me that can do thesame effects? I perticulary like their release function, where it resets everything back with backspin.
And other question...aranging songs in VDJ folders??? Anyone? Why I can not arrange them in the order I need to play them?
Thank you
geposted Fri 28 Oct 16 @ 3:15 am
There are many things you can do with scripts including kill all fx with this script
effect_disable_all
you can string scripts together so you could kill all fx and then call the back spin
folders in vdj are your o/s folders, they can be ordered by alphabetized tracks, or by bpm etc
if you want a play order you make a playlist.
geposted Fri 28 Oct 16 @ 4:21 am
