Topic: Help connecting numark nv2
Hi all, I've just brought a numark nv2, when i connected and opened virtual it detected the mixer and i clicked use this mixer, now, the left deck will not scratch at all but the right decks work fine. I've tried all the buttons on the controller like scratch etc but Still nothing? Thanks
geposted Fri 28 Oct 16 @ 1:11 pm
Open VirtualDJ Settings-->Controllers tab
Select (Click) on the Numark NVII unit from the top-left list
Each time you press a button or move a fader on the actual unit, you should see the relative Key on the right-side Key list.
If you then touch the left platter, do you see the JOG_TOUCH key coming up in that list ?
Also check in OPTIONS. What do you see for the setting "VinylMode" ?
geposted Sat 29 Oct 16 @ 4:03 pm
