Apologies if this is covered somewhere else, but could not find any described situation matching mine.
System details:
-13" MBP Retina on 256GB SSD (32GB still of available space
-VDJ 8.2 (latest build) (Pro/Infinity)
-Pioneer XDJ-AERO (latest Firmware)
(otherwise please see picture attached, also for the settings of VDJ 8.2)
I dj once a month at a gig that is purpose built for (rave) parties, where sound can achieve extreme levels. It has top/state of the art Hi-Fi sound system, separate power supplies for lights and music, etc.
At the last two gigs two different songs (randomly) went silent/skipped for 2-3 seconds. One time it happened on Deck A, the other on Deck B. I was able to see that both times it happened in the second half of the relevant songs, if not more towards the end.
The podium where the DJs set up is right on top of the bass, however the SSD hard drive should not be susceptible to the bass. Also, there is a smoke machine, however both times it was not on.
When I set up the system at home, the same two songs (and for that matter any songs) do not skip and play smoothly.
What could be the issue? Would anyone know what a possible solution can be?
Many thanks in advance.
System details:
geposted Sat 29 Oct 16 @ 8:43 pm
